Postby
eman5oh »
https://forums.nicoclub.com/eman5oh-u154017.htmlSun Feb 14, 2010 6:20 am
Hello, I have read though all of the FAQ and didn't find the answer to this question. Does the factor radio have a rear aux jack or input on it? If so what type, 1/8" stereo or rca? I will taking delivery of a new 2010 Rogue S AWD with 360 package. It does not have the Bose system. Thanks
Modified by eman5oh at 8:46 AM 2/14/2010
Postby
philipa_240sx »
https://forums.nicoclub.com/philipa-240sx-u68765.htmlSun Feb 14, 2010 2:25 pm
There is only one line input jack on the front of the radio. There is nothing on the rear. There is also no way to add an aux input to the base model radio either.
Your only option is to use the one on the front with a cable.
Postby
eman5oh »
https://forums.nicoclub.com/eman5oh-u154017.htmlMon Feb 15, 2010 4:44 am
Thanks, that is what I was afraid of. Do you or any one else know if the antenna connection is a standard type? I am looking to install a Sirius Radio and will use the direct fm connection to hide all of the wiring. I know on my volkswagon i needed a 90 degree adapter due to no room behind the radio and know that some cars have non standard antenna connection.
Postby
eman5oh »
https://forums.nicoclub.com/eman5oh-u154017.htmlWed Feb 17, 2010 4:24 am
Thanks I got my car the other day and am loving it. I also placed the order for the antenna adapators. I was going to use a isimple ISNI11 gateway to add the sat radio to the car but My Rogue has the base radio labeled PY00F on it that is mentioned as being not compatible. Anyone have a base radio from an 08 that they want to sell?
Modified by eman5oh at 6:56 AM 2/17/2010
Postby
philipa_240sx »
https://forums.nicoclub.com/philipa-240sx-u68765.htmlWed Feb 17, 2010 3:36 pm
Unfortunately you cannot add the BOSE radio to a base model Rogue. There is an external amplifier that is required for the BOSE system to operate and is not easily retrofitted.
