OK, I got the block-off plate in today and tried to remove the EGR top unit from intake manifold.It's a 2 piece and I managed to remove only the top piece. the bottom piece (which gets feed back from exhaust) has three bolt and only 2 would come out. The inner bolt is so much inside the intake manifold I couldn't get to it even with twist rachet or small 12mm wrench. Got any idea how it can be removed w/o taking off the intake manifold?
I managed to block all the vaccum hoses by using caps. I block them at the front as well. One larger hose up the front was sucking in air like crazy.As for the pipe back from exhaust which has been cut open, I taped it with masking tape and it holds.
The engine having 'Hiccups' under acceleration seems to have lessened, not really sure yet since I don't want to drive my loud car at night while cops are prowling the streets. I felt a bit 'Hiccup' on shift up to 3rd while at 2K rev. Maybe it was low rpm. I'll try to drive some more tomorrow and see how it is.
Off topic, I got 2 new KUMHO 195/55/15 Ecsta Sport tires for $50 a piece (no tax) for my girl's Cavalier. Tirerack sells them for $62 a piece + S&Hhttp://
www.tirerack.com/tires/...ing=Y
