Radiator
elbles
Car: 1990 Nissan 240SX SE Fastback
Well, yet another problem as the result of the former owner of my car being a complete moron . . . he apparently put the 91+ radiator in it instead of the appropriate one for the MY (1990), and it didn't quite agree with what the hood thought its position should be. :-) (Translation: hood put a nice dent in the radiator, and eventually caused a pinhole leak, which is what I have now).
My questions are, 1. How hard is it to replace the radiator in this car?, and 2. Anything special I should keep in mind when I do it? I have the FSM, and it doesn't appear too hard, but "real world" tips are always helpful . . . thanks, in advance.
180fan
Car: 89 fastback
radiator isn't too hard. most people get tripped up by the bleeding though.
1. dump the coolant from the radiator by uncapping the cap at the top, and unscrewing the bleeder valve at the bottom of the radiator2. undo the intake and move aside anything up at the top obstructing your moving the shroud off3. if you've an auto, now's the time to undo those two coolant lines at the bottom of your radiator and cap the lines.4. Take off the coolant hoses5. undo the lower part of the shroud around the fan, the part that is a big O.6. undo the 4 or so bolts holding the shroud to the radiator and lift out the shroud7. undo the top two brackets that hold the radiator in place8. lift out your radiator and take the little rubber caps off and put them on the new one, there's 4 total, two on top and two at the bottom9. reverse the order above for install10. pour coolant into your radiator, sqeeze upper and lower hoses to make sure you get as much coolant in there before starting the car up and remember to fill up the radiator. burp as discussed many times on the boards
elbles
Thanks for the reply; the bleeding is the thing I'm sure I'll have a problem with, heh, I'll do a search on that, but in the meantime, if anyone has any more info to contribute, I'd appreciate it. Thanks!
180fan
Car: 89 fastback
pop the screw on the intake manifold that has the little yellow sticker and fill till the coolant pops out the top. cap that bolt, and cap your rad. squeeze your upper rad hose and it might help to have the front of your car lifted. undo cap and keep filling the the sucker's full. take her off the jack stands and start her up and fill more while squeezing the upper and lower hoses. turn off the car (don't run for too long) and wait for the coolant to cool down so you can pack in more coolant. repeat as necessary
UTWarrenG
How different is the DOHC radiator from the SOHC?
Reason I ask is that i have a DOHC radiator in my 92 with the seized motor, but the one in my 90 is all gunked up and we're swapping in another '90 motor to the 90 and i really need to do this affordably
Dattebayo
they have the same radiator style, if thats what you mean. plug and play between the two.
elbles
I can tell you I believe I have the DOHC radiator in mine, and it definitely doesn't seem to fit right. :-) The hood put a nice dent in the radiator, and it appears to be in as correctly as possible, considering it's likely the wrong radiator. Anyone else know anything about the differences?
elbles
Anyone have anything to say about the location of the block drain plug on the KA24E, or what coolant to use???
elbles
I already have some Prestone 5 year/150,000 mile pre-mixed stuff, and it's orange, someone said I should only use the green stuff . . . anything I should know about that would be helpful. :-)
180fan
Car: 89 fastback
orange, green, it's all the same stuff. personally i use the prestone green stuff and mix in 50/50 with alhambra distilled water.
Dattebayo
the only thing i know is that they are supposed to be the same radiator. maybe you have a s14 radiator in a s13 or something, cause i changed out (personally) my DOHC radiator when it was clogged with a radiator from a 1990 SOHC and it fit perfectly.
maybe you dont have the rubber pegs in the bottom lined up correctly or the holding straps on the top have lost the rubber things.
also, i was told by a dealership monkey that different colors of antifreeze should not be mixed (i.e. red w/ green). some of the different chemicals that make the color may cause a reaction and clog your radiator and/or lines up.
UTWarrenG
Noooooooooooooo it's not all the same stuff.....the orange is for the newer cars, usually with aluminum blocks.....if you mix the two you'll eventually get jelly
It definitely doesn't mix well
Using the green stuff in newer cars doesn't provide the proper protection needed for those engines, and they'll rust prematurely inside.
Can't remember exactly what happens if you use the orange stuff in an older car, but I know it's not good....
Bottom line, don't mix don't mix don't mix!!!
elbles
The FSM only recommends using something that's in this Prestone stuff; no other recommendation is made within the FSM, so I used it, I doubt I'll see any ill effect from it (or so I hope). I flushed the system pretty well, by leaving the radiator drain plug open with the car running, while adding water to the radiator until it started coming out clear, so I don't think I'll have to worry much about the mixing. Thanks for the reply!
elbles
Oh, and after doing some research on Google for "types of coolant", and a few reads later, it seems that the "orange" stuff shouldn't be used without doing a through flush and making sure you have an aluminum radiator (which I believe I have, haha). After that, Prestone says you shouldn't have any problems using the orange stuff, though I doubt I'll take it to the 5 years/150,000 miles that they say you can, and it will probably be flushed out within a year anyway. Thanks again for the info, it lead to a lot of other info, heh.
navysnail
like said before, dont mix it, that hapened to my moms pontiac and did like 1500 dolars in damage. the drain plug is on the exhaust manifold side of the block
elbles
I flushed the system well, so there shouldn't be much of a concern there about it mixing. I did learn where the block drain plug was, but I couldn't find it still, haha, so I just left it. You might ask how I flushed the block without pulling that, but by leaving the engine running with the radiator drain plug out, and racing the engine while filling the radiator with water (to keep the thermostat open) seemed to flush it completely. Thanks for the reply though . . .
Dattebayo
so did you resolve the fitment issue? I left you a world of info a few posts up.
elbles
Yeah, I did, thanks man. I'm not sure what radiator the car had in it (it was installed by the last idi-I mean owner :-)), but I ordered what Levine Auto (local auto parts place) said would fit a 1989-1994 240SX, and it was the same one. Upon removal, everything looked fine, the rubber mounts were fine, et cetra, and everything went over to the new one just fine. The difference is the new one doesn't hit the hood, and I can check my oil without fear of killing the radiator. :-) Thanks again for the info, sorry if I didn't give you due respect before . . .
Dattebayo
not at all. i just wanted to help and stuff.
180fan
Car: 89 fastback
whoa that's good stuff to know that they shouldn't be mixed.
elbles
Now that the install is complete, I just had a question. Once I was done, I had the car idling for quite a while, just to see how it was working; the upper radiator hose was getting quite warm, while the lower one felt just fine to the touch. If I raced the engine for a few minutes, the bottom hose would get warmer. I assume this is how the system works, correct? In other words, the hot coolant would come in from the engine to the top of the radiator, become cooled, and come back out the bottom, and that is the point at which the temperature gauge's temperature is reflected? Just making sure, heh . . .
Dattebayo
electronic coolant temp sensor is at the top hose...thermostat is at the bottom...
elbles
Can anyone confirm whether or not the situation that I described above is the way it should be? My 240 paranoia sets in . . . ;-)
elbles
Oh, and 2BN, there was some sort of sensor at the lower hose, 2 or 3 wire sensor . . . maybe it was different on the E???
elbles
Anybody? Bump . . .
ricebike
2002 Quest
2005 Altima
elbles wrote:Now that the install is complete, I just had a question. Once I was done, I had the car idling for quite a while, just to see how it was working; the upper radiator hose was getting quite warm, while the lower one felt just fine to the touch. If I raced the engine for a few minutes, the bottom hose would get warmer. I assume this is how the system works, correct? In other words, the hot coolant would come in from the engine to the top of the radiator, become cooled, and come back out the bottom, and that is the point at which the temperature gauge's temperature is reflected? Just making sure, heh . . .
confirmed: yep it works that way...therm closed means engine still in "warm-up" period. hot coolant out from engine --top hose--radiator--lower hose--tstat--> till that wax pellet in the tstat expands & lets more coolant into the engine...
plus, I too have the infamous orange coolaid/distilled water mix in my car; i flushed mines out completely <3X> w/ taking that other drain plug on the block... kept it in there for the past 5 years & when I change it again <w/ new hoses,radiator cap & tstat>, the radiator/overflow was completely clean:ylsuper
I don't have to worry about the system for another 5 years, unless u got a crappy tstat
ricebike
2002 Quest
2005 Altima
elbles wrote:Oh, and 2BN, there was some sort of sensor at the lower hose, 2 or 3 wire sensor . . . maybe it was different on the E???
that "thermoswitch" works w/ the AC system to activate the electric condensor fan... hmm i better check if my electrical fan works by jumping some wires... <my phobia: to f something up, but i gotta learn about electrical sooner or later!>
