nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Tue Aug 07, 2018 8:40 am
I agree with Ace, definitely check the 2 heater hoses. If they are leaking get some silicone hoses.
Its a little bit of work, but at the rear of the engine, where the heater hoses attach, there are a couple of t's that come off of them. Block them off or run a hose from one to the other kinda thing. The coolant lines under the plenum are just not needed, even in the cold weather, I never had an issue when I had my older z's. But that would be the only area that they could leak.
The only other option to look at are the freeze plugs, but those should be obvious to a competent mechanic.
Have him run a pressure test when cold on the cooling system. He could add a dye in the system if he is having that much of an issue. Tell him to stop throwing parts at it at your expense.
