N/A Q45 wrote:Why don't you just go buy new caps and put some grease on the rubber, at some point you're more then likely going to have to revmove it/ them anyways.
Whoa, that didn't sound good. No only will i get another cap Monday from my Nissan/Infiniti specialist. I'm gonna let him take off old and put on new...lolOwnerCS wrote:It is good to replace caps as preventative maintenance items and definitely if the gasket becomes suspect in any way.
One of our senior members that owns a repair shop in the Atlanta area almost lost his Q's engine over a failed cap.
For no more than caps cost, why worry?
Check out the following post.
post5745190.html?hilit=cap#p5745190
Yep! I ain't trying to end up like that. You guys may have saved me some serious heartache. Hopefully i haven't spoken nothing into existence before Monday. I will get a new one then.qship96 wrote:If you search his post history.....you will see he basically disappeared from this site right after this happened too.....must have really affected the old boy.
