radiator replacement
luckyone
Car: 1993 nissan 240sx covertible
Hey Guys,
1993, 240sx vert, replacing radiator, have all upper and lower hoses and connections off how do I remove the fan shroud, I can only find two screws is that it?
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
I thought there would be 2 on the bottom too
asoomal
Car: 2001 Subaru Impreza L 5MT (Daily)
1992 Nissan 240SX SE 5MT w/HICAS (Being restored)
Two screws on the top that hold it down, remove air intake as well.
And then on the sides of the shroud, there are plastic pieces that sort of hold the upper and lower part of the shroud together. Be very careful with these, as they break very easily (there's even a TSB on how to remove it safely lol). Then push the clips down, where the upper and lower shrouds meet. It should pop off and come out easily.
luckyone
Thanks, I will give it a shot.
biggie
4 screws total on the shroud, 2 at top into the radiator and two on the bottom on the corners. Then there are 4 "clips" that hold it together in the middle.
Just removed mine this past weekend.
luckyone
Thanks for the Pics and advice. I finally got it off and was able to remove old radiator, Now I get to reassemble AWWWWWWW
biggie
Can be lazy like me and just remove the shroud and clutch fan. Just running the stock electric fan and eventually some alitma dual fans.
luckyone
Naw Thanks,
Its a single owner (ME) 240sx vert, I like the OEM approach
