Chezedik »
https://forums.nicoclub.com/chezedik-u3691.html
Fri Oct 01, 2004 9:48 pm
#1 I work at Advance Auto, so everything from Autozone sucks (unless they start signing the checks, then they are cool with me!) #2 a lot of people have this problem at work, and the very simplest of solutions is to drill and tap a hole on the highest point on the cooling system to bleed air, but since you are running a KA, you will notice on the intake manifold you have a bolt labeled something to the effect of 'Hot, do not loosen until engine is cool'. Wait until it is cool, then pop that bolt out. Then you will pop off the radiator cap, and add coolant until it comes out of the hole. Then cap off the hole, and let it run. In my very personal experience, this motor likes to hold onto air, and doing this should help. Changing the Thermo only made my problem worse. Hope that helps.
