ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Wed Jun 22, 2011 6:48 am
New to you car! Stop! Now use logic, your brain, car stinks, car pukes coolant. You do not know where or why its doing this so investigate!
Drain the coolant completely, examine it for content, do not use stop leak because you do not know what your stopping a leak in, what size or where.
With system drained look for particles, gaskets, bronze, anything. Check the rad for blockages, check the thermostat for working correctly, check the quantity of fluid removed as per the book.
A full coolant system needs expansion room, check the expansion bottle.
A full coolant system is never full, needs room when hot. Check the cooling fan clutch.
After every component is checked you should have an idea what is wrong, make sure you clean out and flush the complete system, then refill with no silicate anti freeze at 50/50 with distilled water.
Take your time and do it right then you should be good.
While all coolant out and from your comments I would do a compression check to test that head gasket, wide open throttle, charged battery and a decent gauge.
You may find another problem.
