Lars »
https://forums.nicoclub.com/lars-u19851.html
Thu Jun 04, 2009 9:06 am
Chuck is right, somehow air is getting into the system. The cap is a quick one to replace, but you NEED to top up your coolant. If you get an air bubble stuck in the system that could cause it to push the coolant into the catch bottle, and cause your truck to overheat. I haven't serviced the cooling system on my pathy, but there is usually an air bleed somewhere high in the system that will allow you to get the air out. Just checked the FSM, there is an "air relief plug" that will help you get the air out. If you are concerned about the head gasket, there are a couple obvious signs that it has blown:1. lots of white smoke out the tail pipe 2. When checking the oil or looking at the underside of the oil fill cap it looks like someone filled you engine with a chocolate milkshake and 3. coolant shooting out the side of the engine while running (yes, it can happen, I've had it happen).
The throttle body and MAF are completely unrelated.
