radiator not replenshing from reservoir
tetsuo
My radiator fluid goes low but it doesn't suck any fluid from the reservoir. What would cause this?
Thanks!
94_240sx
Car: 94_240SX
Radiator cap seal should open and close when there's a pressure. Take a look at it. You will see a rubber flap on the cap. I'd try a new cap and see. Make sure the hose is not clogged.
