Ok my friend, i took one piece of advice you gave and put a little oil down in the spark plug tubes, finally started to shoot waterish looking stuff out. I did not detach any fuel lines as i really have no idea what I’m disconnecting. After a few attempts i was able to crank the car and a hella big cloud of smoke poured out of the exhaust. I let that run it’s course, put more gas in then drove around the block. It’s not running great, not really even good but it’s moving so i have some hope. White smoke is still coming out of the exhaust and up hill driving is especially sluggish. Would running through the gas help this to correct itself or should i add some “heat” in order to remove remaining water? Any and all advice greatly appreciated. Thanks for the initial help as wellQ451990 wrote: ↑Sun Mar 11, 2018 3:50 pmWow... that sounds like you have your engine has no compression... something is very wrong. Depending on how much water you got into the engine, it's likely hydro locked. It depends on how much you like the car, and want to keep it running, but I think I would seriously consider professional intervention on this. Just the amount of fuel that's in your injector rail is surprising. When I've done rail flushes with injector cleaner, it's amazing that you'll go a good block or two before the cleaner is out and pushed through by the fuel.
If you want to keep taking your chances on DIY, as others recommended, disconnect the fuel lines and purge them. As far as the injectors, I don't know if the M has a return line to the tank, but you might try disconnecting it and seeing if you can purge all of the bad mixture out of the fuel rails that feed the injectors. If you've removed the spark plugs, I'd squirt a bit of oil in the holes in hopes that the lack of compression is just that the bad fuel mixture washed off the oil film off of the rings. The oil might help that.... of course it'll smoke on startup if you get to that point. I would also change the fuel filter. I think it's integrated in the fuel pump assembly.
Thanks for the advice, i was able to get the car started after putting some oil down in the spark plug tubes. It runs like crap currently but it is running. If i knew anything about what is under my hood i would have gladly taken your advice but honestly i do not. It’s currently smoking like hell from the exhaust becuase of the oil, I’m hoping that it will correct itself by burning through what’s in the tank but i fear that’s quite optimistic. If any other lamen advice is available i will gladly take it. At this point i hope i can drive it to a mechanic or use it as a trade in.EdBwoy wrote: ↑Fri Mar 09, 2018 9:59 amHi there, what a day. How do you get coolant and fuel combined into one container, accident? I suppose no need to advice you about labeling containers at this point, hehe.
You had my hopes high to see a geyser and hot springs show from the engine, but that sucks.
What I'd do at this point is disconnect the quick connect fitting at the passenger strut tower. Get a flexible hose/tube from that metal tube and direct it away from the car then activate the pump to eject any water thay might be hanging in the tube.
Then grab the flex hose leading to the injectors and drip out whatever is in there.
Then reconnect and try again
No offense taken, you are right i am not mechanically savy. I have managed to replace so much under the hood that i had a bit of confidence built up, plus money is tight so you gotta do what you gotta do. I did not know that oil and gas ever crossed paths in the engine so I’ll check that now and see what i can resolve. The bad fuel was completely emptied first thing on this project.LIBRILZ wrote: ↑Mon Mar 12, 2018 11:19 pmwhy are you putting the car under load? you are really going to do more damage to it now, if anything you should've changed the oil immediately, took out all plugs and cranked it, and found a way to drain the old fuel, as you could still be putting water back into your engine
from the sounds of it no offense but you don't sound mechanically savy, I suggest you take the car somewhere as others have already mentioned
On the way home to check it now, I have not been driving the car around other than once around the block. I did not realize that water in the gas tank would affect the oil. Thanks for the advice
