qship96 »
https://forums.nicoclub.com/qship96-u3104.html
Wed Dec 05, 2007 1:08 pm
Order a new radiator TODAY,any competant shop can flush out all the goop you put in real well,and install new radiator with all 3 hoses.Consider replacing water pump,thermostat,all 3 idler pullies and 3 belts especially if all these parts are original.Infiniti radiator is crazy expensive {$600+},I installed a aftermarket CSF brand,and seems to work just as well,and fits perfectly,cost $200 or so,couldnt see the the value in spending the $ on OEM radiator on a 12+ year old car that will be retired in 2-3 years,or sooner if it gets in an accident/stolen.
Ps-I had T3replace my original waterpump at 201,000 miles as preventive maintenance while I was having belts, original thermostat & pullies changed,and it still looked good with no corrosion/erosion on impeller and bearing still smooth and tight-maybe it would have lasted til 300,000 miles? for $112.00 it is cheap insurance against a breakdown on side of road.
