ricebike »
https://forums.nicoclub.com/ricebike-u5064.html
Thu Dec 29, 2005 8:54 pm
sorry snail for the slight mis-information... (i was thinkgin of sis' 97 chevy cavalier, which has a pressurized cap on the resevoir & none on the radiator itself!)
but I assumed that this is a "closed" system, using the radiator cap's pressure/vaccuum valves to regulate the system's level & to keep from ingesting air bubbles, if the resevoir is intact.
GU, u gotta look around the engine bay... dripping near water pump? hose clamps? near the intake manifold/throttle body? heater hoses near the firewall?
If you can't see the leak normally, goto the parts slinger & pressurize your system while car sits there... confirm the leak by seeing that the gauge is gradually losing psi... pump up again & start doing a visual @ all connections...
last effort: using a dye & UV light...
PS: my resevoir tank is cracked too, but above the full level mark... a hot glue gun & 2 sticks made a quick band-aid & since this plastic tank isn't pressurized, this item is in the backburner for a replacement.
