Radiator hoses?
Julio Bro!
Car: 1993 240SX SE, manual transmission, Stillen intake & strut bar, Magnaflow cat + custom cat-back, NISMO sus
Hi:
I had to do an emergency raditor hose replacement and got a universal hose with the metal coil inside. The fix worked and the hose looks tough, but is this kind of hose the type that could be left installed?
If it's not good, are there, like, performance radiator hoses or should I get an OEM part?
Thanks in advance.
180fan
Car: 89 fastback
The universal hoses are fine. Just if you want the better fit and probably longer life, go with the OEM if you plan on switching motors sometime soon. If not, then go with the aftermarket hoses.
Julio Bro!
Are there any performance (as in more heat resistance or less deformation) hoses available?
dabum
im pretty sure there arent any performance rad hoses for the ka, i think only the sr has one. samco rad hose.
Julio Bro!
I see Samco makes a set for the SX 180 with the CA18DET 1.8L engine and the picture shows hoses that look a lot like the 240's.
Could those fit?
Ni2s4s0aSnX
Car: Nissan 240sx 2.4L 12Valve
Yeah, there are some aftermarket, or performance, radiator hoses out there for the KA, but it will probably cost you around $120 for a set. If you are willing to spend the money. I give you some sites where you can find them. Try these. But I think they're all for the SR./i-m-racing.com
Modified by Ni2s4s0aSnX at 8:14 AM 6/3/2005
Julio Bro!
You know, I haven't found any, just for the 180SX and these are $80/set at OPTIONS. Well priced, but double the cost of rubber.
I'll check a few places more, but I'll probably go with rubber.
Thanks.
