Radiator hoses are swelling?
helix73
Car: 91 240sx SR20DET 23lbs
So ive recently noticed that my radiator hoses are swelling. Ive kinda heard mixed things about this, maybe head gasket is bad, or is my water pump failing?
Im bleeding my radiator in the morning to make sure.
Any suggestions?
2_Liter_Turbo
Car: _________________
'96 S14 Coupe: SR20VET
'90 R32 TH1 GTR: RB26DETT
'92 S13 Fastback: SR20DET
'11 V36 Sedan: VQ25HR
'06 GMT800 2500HD: LBZ Duramax
I would say either you are getting compression into the coolant system or you have very bad cheapo hoses. Hopefully the latter!
Cone Killer
Car: 1991 240sx
The only time I've ever seen rad hoses swell was because the hoses are bad. Unless your car is running really hot all the time, but even then your radiator cap should release the pressure before your hoses swell. Unless your rad cap is a high pressure cap.
Best hoses to use IMO is stock hoses by Dayco or Gates, they don't look pretty but they are more than suited for high performance use. Hell even the NASCAR cars run the same hoses you get from the parts store.
