Radiator hose losing pressure?
methodchris
My radiator hose periodically will lose pressure and when i check it i will be sucked it, so i replaced the hose thinking that it was the problem but it wasnt... I was thinking it could be the radiator cap? only other thing i could think of.. help if ya could
97 240sxGReddy cat-backWeapon-r intakeHotshot header17" ADR skye 7's
180fan
Car: 89 fastback
um what do you mean lose pressure? You mean like it feels like there's no more coolant in there? If that's the case check around for leaks. Might be small, but check around. Could be the cap's spring has gone which could explain the periodicity but dunno. I've never had that happen before. You might have a small leak in your radiator too. Might want to check those out.
NISTECH
if the hose is collapsed i would say your rad cap is not allowing the system to pull coolant in from the overflow bottle. if you mean the hose is extreamly soft when the car is running it is possible the pump isnt pushing the coolant well enough. do you have an overheat problem associated with this? once the car is shut off it is not uncommon for them to loose their pressure rapidly.
topless@vabeach
Car: Electronics, anything that has trons in it.
How is your coolant level? You might have an internal leak. Check your oil and see if it looks milky or like old chocolate milk.
Is your car running hot. Any details would help. More the better.
yellow_jacket
Car: 95 240sx
You should have vacuum in your cooling system after you turn the car off(After it begins to cool). It sounds like your vacuum may be a little excessive. I would take a look at your radiator cap.
methodchris
yeah it was the cap, thanks
