Skibane wrote:
Mine, at about 73K:
Yup, that's what happens to 'em.Thanks for the photo which shows just how bad it can get, skibane.I wonder how many other members have rads that look like that and don't know it.
Note that if you start out with a clean radiator and shoot moderately high pressure air through the radiator from the rear, it shouldn't get that kind of buildup. Soapy water under pressure would help too, but not sure if that might damage the fan motor. I'd be careful doing that, and would only uses it as a last resort to remove heavy buildup and you don't want to remove the radiator and A/C condenser.
And Q45tech is right. Air leakage= poor cooling. Only if the incoming air, ALL of it, passes completely through the radiator will the cooling system operate effectively. I suspect many members suffer from this problem too.
Cooling system flushes, replacement of thermostats, hoses, and radiator caps is necessary, but so is exterior cooling maintenance. It's a commonly neglected area.
