Rivalry wrote:I've heard that having your radiator "flushed" out doesn't really do anything performance wise. Can anyone enlighten me on why a flush of the radiator fluid would be necessary? Thanks.
If you are referring to a new vehicle, my opinion is to check the coolent with a tester yearly to be sure that it will not freeze at least down to 10 below zero or more if you frequent colder climates. After 4 or 5 years belts and hoses would need to be replaced so that would be the time to do a flush. In addition, many vehicles require a timing belt change so if that work is being done that would be the time to do the belts hoses, thermostat and the radiator flush.
If you purchased a used vehicle with 50 or 60k miles and you have no proof that any of the above work was ever done then it would make sense to have that work done.
Just doing a flush without taking into account the other items doesn't make sense to me. Again just my $.02
Telcoman
