Hey folks,
I am taking a road trip at the end of June to Vegas, and I'm very concerned about overheating - especially because I have a CVT.
I realized that I hadn't flushed the radiator since I bought it, and I assume the previous owner did not do so because Nissan's coolant is marketed for long life. The car is an '08 with about 35,000 miles now.
I bought a coolant wetter to help make the coolant more effective, and was considering using a higher water to coolant ratio - about 70% water, 30% coolant. Before flushing it myself, I checked out the service manual (
http://www.nicoclub.com/FSM/Altima/2008/co.pdf p.32-33) and they advise using vacuum tools when flushing the radiator - things that I don't have.
Have any of you flushed the radiator yourselves? If so, did you use any special tools? I figured I could just open the radiator cap and the drain plug. Flush it with distilled water and run the engine a few times in between. Then fill it up with the water/coolant/wetter mixture. But then I ran into a problem. I can't get the radiator cap off. I can loosen it, but it's stuck. There are two edges that are crimped down that help the cap make a seal, and prevent it from turning too far. But no matter how much jiggling I do, I can't get the cap off. I don't want to force it, because I don't want to damage the cap. Any suggestions?
Thanks!
