drewtorn »
https://forums.nicoclub.com/drewtorn-u79293.html
Wed Jan 30, 2008 9:00 pm
Kenny, Thanks for your reply, unfortunately I have discovered the leak and it appears to be coming out of the water pump gasket! I have a stupid question,does leaking mean a water pump is typically worn out or is the main problem a sealing problem ala a gasket, what i mean is if you replace the gasket is the leak usually fixed and is replacing the pump necessary if it still works? and do most people replace the water pump even if it is still working? Again, any wisdom is very appreciated! Drew
