Radiator fins
Tenchu2201
Car: 2018 Nissan Rogue Sport
I have a 2018 nissan rogue sport.. One of my children decided to run something back and fourth on my radiator fins and bent A LOT of them.. Could this be causing my car to over heat?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Yes, if the damage is closing off too much of the airflow through the tubes and fins. The device closest to the grille won't actually be the Radiator, it will be the A/C Condenser, but air must pass through that to reach the radiator. If your A/C still works at all then chances are only the fins are damaged and not the tubes, so you can probably get in there with a sharp pick and carefully unbend the flattened areas to restore the airflow. It may take you several hours but it will be much cheaper than a new condenser.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Fin Straightening Tool - Top 5 Best AC Fin Combs Reviewed
https://hvactrainingshop.com/best-ac-fin-combs/
Return to “Rogue Forum”
