xerexabante wrote:I drop my pan change filter and drain every 6mo. never had transmission problems. as long as you do it and more often the better. machine, well up to you. i'd rather do it more often. when you have the machine flush you tend to have less interval. 6mo. tops and do it again.
I agree on the simple 1x drain/fill every 6 months to maintain fluid perpetually if thats your chosen method as compared to multiple {6x} drain/fills every 25-30k,but the pan drop/filter replacment every 6 months is a total waste of time & money-you gain absolutly nothing by doing this procedure at these frequencies.The filter{screen} is there to block chunks of material from circulating thru transmission after a catastrophic failure only,and if ever clogged enough to warrent replacment due to restricted atf flow,the transmission is already in need of rebuild/replacment.So many people on this board dont understand the needs of a transmission and either underservice or way,way overservice the screen change interval buying no increased transmission life.......My q currently has 194000 miles with 1 screen change done at 114,000 miles{screen,pan,and magnet were all clean according to my eyes and the tech who did the service} and 25-30k full fluid replacments with Full synthetic fluid{redline d4} either using the exchange machine{earlier years} and recently using the multiple {6} 2 minute timed drain/fills as per q45techs post-the external canister filter has been changed 1x-this is THE REAL FILTER on the trans-similar to a motoroil filter that removes fine particles from the fluid ,unlike the internal chunk catching coarse screen-transmission operates as new still using my methods.
