Jeka619 »
https://forums.nicoclub.com/jeka619-u254240.html
Wed Jul 22, 2015 2:56 pm
Hi Guys,
I am new on this form and would like to say HELLO to everyboby.
Here is my story.
Recently I was struggling with radiator fans on my lovely Infiniti M35 2007 with 114K miles on the clock. The problem was discovered yesterday morning, when I turned the engine on. Both radiators fans started running as crazy. First, I checked the A/C to make sure it's off. Then, I was driving all day with the radiator fans on 100% of the time. Even being in sunny California, the engine temperature did not go over 180F to open the thermostat because of the running fans. Initially, I thought it's thermostat issue. I unplugged the fans and turned the engine on. After 5 minutes the temparature reached 180F, the lowest hose from thermostat to the radiator became hot. So, I rulled out, the thermostat is Ok. Next, I checked the fan relay. The relay was good as well. The last electric part of the cooling system is a radiator fan contol module. This toy is sitting right in the back of the fan shroud (p/n A18700A28001). Having replaced the module, the problem was fixed. Now, my car is back to normal. I hope my experience will help folks that facing the same problem.
Enjoy your driving
Jeka
