OutToWinPAHC »
https://forums.nicoclub.com/outtowinpahc-u66900.html
Mon Jan 25, 2010 5:00 pm
Via the print there is no problem doing what you did, but you will have voltage drops from the two sources, one being battery via the relay, and the other from the ignition relay. The ignition side will be loaded, and now you are backfeeding the circuits via the battery fan relay throught the other relay back into the ignition relay.
If you want to use these here use one per fan, have low purn on one fan, and high turn on the other fan.
