Radiator fan relay
A forum for lovers of Infiniti's hot-rod crossover, the FX! In 2014, all FX models will be named Infiniti QX70, in line with Infiniti's new naming structure.
crankor
Car: 2011 Infiniti FX35
Does anyone know which relay controls the radiator fan on a 2011 fx? Theres nothing that is directly saying its for the cooling fan/radiator on any of the fuse boxes other than a 50 amp square fuse. Closest thing to it would maybe be the pmw relay?
* I ended up pulling the pmw relay (the only one i had in that particular box) and did the multimeter test and it read 89 so from that i would assume its working. although i tried using a 9 volt battery on it and didn't hear it turn on but i think i needed a 12v anyway for that to work. Sooo i'm out of ideas as to why my radiator fans aren't working. They don't turn on through the scan tool either.
crankor
i guess the cooling fan module i already replaced with a newer used one could be bad?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
In those setups, all the fan relay does is supply battery voltage to the control module. If the module has 12V power with the key on, the relay isn't the issue.
Return to “Infiniti FX35 / FX45 / FX37 / FX50 / QX70 Forum”
