Is it best to get an OEM replacement from the Dealer or is there a reliable/trusted aftermarket source available ?
Yes I'll be keeping the car so I am not looking for "something to throw in there"
('90 Manual 240SX Red Hatch)
Actually tests have shown that the stock fan and shroud setup flows more CFM than any aftermarket electric setups. Also having your electric fans running full speed all the time is inadvisable as it will just wear them out faster and probably keep the engine too cool. (yes there is such a thing) The purpose of the cooling system isn't just to remove as much heat as physically possible, its to maintain the engine at its optimum operating temperature. Now for fire breathing turbo cars like some of us have, these two goals are pretty much one in the same LOL, but for a mostly stock vehicle, its overkill.liquid_cool wrote:wow..no one told you..ok..i will...switching to an electric fan will free up about 5 extra poneys man..parasitic drag on the motor from a clutchfan set up can be a limiter, as for dealer parts,there big bucks for the same amount of coin, you could have sprung for the ISIS fan and shroud kit..makes the engine bay look way cleaner and you will run way cooler as the fans run max speed all the time..just my 2 cents worth.
