Radiator Fan Assembly Always on High
Igorati
Car: 2006 M35 Sport, Nav, Premium
So I have a second issue.
The radiator fan assembly is always on the second I turn on my car and it is always on at full blast. The service manual speaks of a failsafe mode which makes the fan go on HIGH all the time. I repaired this car from a front end collision so I am using an aftermarket radiator fan.
I took it into a shop and they plugged up some computers and tried to set the fan to off and it would not respond. Could their computers not be working.
The manual says you can use Consult II and reset the speeds for various temps for the fan assembly.
Only other thing is that the Fan assembly control unit is crappy and stays on high all the time. I am sure I could drive it like this until the fan assembly dies from over use but the noise is irritating. Any ideas or anyone heard of reseting this. I am thinking maybe Infiniti needs to look at it and use their Consult II to fix it... Thanks for the help.
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
Don't you have another thread about rebuilding an M?
If I had to take a shot in the dark I would suspect the module attached to the fan assembly, if not the IPDM.
Are the fans on high the only problem?
Igorati
Yes, I have other threads but not related to the fan assembly. I wanted to get specific answers back.
I was thinking the module as well (unfortunately, means I have to pull the thing out and send it back).
What is the IPDM? Is that the relay? We tried to use two different relays and that didn't make any difference.
I have my old module so I am going to try and figure out how to attach it to the new assembly (the old one was cracked in a few places). I might even take the fans out of the old one b/c the new one has only one plug in, the other is hidden inside the module.
EL PERRON
Car: 06 Infiniti M45
06 Chrysler 300 SRT8
98 Honda Civic EK4 Hatch Turbo
Hey bud did you ever get this issue fix? Mine just started doing this and its annoying. Looking forward to hearing from you.
vpmtl
Car: m35x
sorry to bump up old thread but anyone have solution for this. mine stared doing this after battery was discharged.
Any way to reset or will have to go to dealer???
Thanks
Mutton
Car: 2006 Nissan Cube
2005 Nissan Fuga 450GT
1991 Nissan Skyline GTS-t
Mine did this, the local Nissan dealer diagnosed it as a faulty fan shroud resistor.
ae7456t
Car: 2006 M35X with 19X,XXX miles
I had the same problem and swapped out the fan control module...
http://www.infinitipartsonline.com/infi ... ame=module
There is a TSB for these modules failing, but our M's might be a little old to claim against it.
Swapping it out is about as easy as it gets. Take out 2 screws, unplug and re-plug.
ZMQguy
Car: 04 350z track, 07 m35x, 02 qx4
Cooling fan Control. Can be found on ebay for $70 for an OEM nissan one brand new.
