You will if you want your car to survive the Houston summer. Otherwise air goes around the radiator instead of through it. Without the under engine tray. the sir goes up from under instead of through the radiator. In hot climate, you need both.Romeo5k wrote:the foam, well, i didnt read this posts until after. Soooo I didnt replace the foam.. I know i suck, ill prolly remove it and do it over.. Probably!!!
Sooooo, replace the foam?? Or ignore it for now???Q45tech wrote:After 6-7 years of exposure, the oem system has declined in ability to exhaust heat, obviously the subsequent years had improvements which improved the reserve, BUT nothing works like all BRAND NEW.
Based on some experiments the rubber foam surround seal can make a 10-15% difference at idle in traffic...........the number od minutes - seconds that the system can stay below 195F.
Once system creeps above 195~200F it is a steady out of control rise, assuming thermostat is wide open and auxillary electric fans are already on full.
It all depends on your tolerance of risk. Personally, I like to eliminate as much risk as I can.Romeo5k wrote:lol.. Illl trust u Brian... Only cause u are next door to me!
