Radiator dimensions
superuber
Does anyone have a pdf file or pic of the 95 rad and dimensions?Looking to get custom one and I'm too lazy to measure it.
captainluigi
Car: 1996 q45t
A $10,000.00 frikin watch!!!!!! you have to much $. i sailed across the atlantic with a guy that had a Rolex sub-mariner. when it came time to get a celestial fix he would borrow my $29.00 Casio for a time tick. funny sh*t! i happen to have all my shrouds & other plastic offf my 96t. i'll let you know in a bit.
captainluigi
Car: 1996 q45t
here ya go. tape was only in inches so i'll leave the conversions to you.
H 19 1/4''' W 28 1/4''
D 1''(core)
mounting bolts center to center 29 3/8''
of course this does not take in the bump outs for trans lines etc.
hope this helps
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
http://www.yourautocoolingsour...U2053
http://www.yourautocoolingsour...61759
Regarding getting a custom one done, I hear these guys make great stuff including Evans NPG+ Waterless Coolant:
http://evanscooling.com/
Click on English, then passenger cars, then catalog on the left side, and check out coolants and radiators.
Q45tech
Unfortunately typical physical size doesn't tell you the important things like weight [heavier the better], fins per inch, metal thichness, air void to obsctruction ratio, back pressure at flow, etc etc.
superuber
Thanks guys. Contacted Griffin. I'm sending mine in for them
Rex
Car: None
There are cheaper or better cooling efficiency radiators out there, but you usually won't find one that's both cheaper and better cooling efficiency. With the aluminum engine, temp is something we should be very concerned about.
