WahlstFJ »
https://forums.nicoclub.com/wahlstfj-u98411.html
Wed Jun 04, 2008 12:04 am
Whilst driving home a couple days ago, the radiator on my daughter's I30t finally gave out (AZ heat +/- 103 deg). It began losing power and she noted the temp gauge heading into the "H" region so she pulled over and called me. She was in a rather inopportune location, so she traveled another 3/4 mile to a parking lot and I met her there and refilled the radiator, noting the two inch crack on the upper tank. The temp went back to 1/2 and we traveled another 8 miles towards home (10 miles away) before the gauge began to climb towards, but not onto the dreaded "H" again. We reloaded the radiator and finished the two miles to home, with the temp staying below 3/4 for the remainder of the trip. I have now replaced the rad and hoses but now the engine won't turn over. Battery checks okay, but just some relay noises coming from under the dash and hood. Oil is clean (no milkshake) and no visible leaks. In following her home, I noticed no visible signs of oil burning or other obvious smoking coming from the exhaust. The engine started fine each time we had to stop and refill during the trip home... (and yeah, we should have probably towed it, but...)Questions: is there some overheat interlock that needs to be reset? could the engine have seized? new engine codes are P0105, P0732 & P0325 (was already getting the P0303 code, probably need injector?)Any direction would be greatly appreciated. Thanks in advance!
