Radiator core support removal?
ThaKid87
Car: 91 240SX in need of much work and a 96 200SX daily driver
Mine is in bad condition, certain things are missing as well. Is this just a bolt on part? Or is there welding/cutting involved in the installation/removal?
Thanks.
LayNLow240
Car: 92 240 coupe
That will be a drill/cut/weld process. Get the spot welds out somehow (recommend a drill for that) then square it up and weld the new one in with spot welds in the same places.
ThaKid87
Gah. This is going to prove to be hard task for me.
Thanks for the info.
180fan
Car: 89 fastback
Yep, if you're gonna drill, you'll want spot welding drill bits. They'll run 15-20 each for decent bits. If you're going to go with the ones that look like hole saw bits, get a couple of those handy, you'll need them. When you do replace parts of the support, remove as few of those parts as possible. It will make the fit better overall and you'll spend less time drilling and rewelding to make the fit decent.
LayNLow240
Car: 92 240 coupe
Also, if you are doing this yourself, heres a tip. Don't drill all the way though the spot welds. drill just enough to get through the core support metal, and not enough to go through the backing metal.
ThaKid87
Wow...
Anybody in Miami? lol.
Thanks for the info guys, I'll try to put it to use, but I don't wanna **** something up.
180fan
Car: 89 fastback
then take it to a body shop. easy as that.
