Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Tue Nov 02, 2004 5:39 am
I drain my rad twice per year [to adjust the % of AF] replace with either 4 quarts of 100% RED AF [Nov1] or 4 quarts of distilled water + RLWW [April1] that way 35-40% new additives at least once per year. All drains and both the filler cap and the overflow cap get exercised and examined..........takes an extra 10 minutes when you do an oil change.
Every 3 years it gets the full block drain, flush and thermostat and 3 hose changes with new drive belts ~~ 45k.
At every fill up 1-2 times per week it gets a underhood look see and overflow bottle level check.........and examination of all easy fluids.
Can't be too careful when you drive a 15 year old car that you want to last another 30,000 miles to 300k.
