Radiator Cap question
I ask good questions
Car: 92 240 SXSE Coupe with SR20DET
Do 1.3 bar radiator caps serve a purpose over .9 bar caps? I know they say that its an upgrade... but does it really make a difference or is it just for show?
ILikeMy240sx
Car: SR Power
Raising the pressure effectively raises the boiling temperature of the fluid.
If your car does over heat for some reason and the temperature is high enough to boil then with lower pressure that temprature will be lower (easier to boil). When coolant turns to vapor -> bad thing.
da40
Car: 1995 SE 240sx
yes it does, i got a blitz cap sweeeeeeeeeeeeet!
