Radiator Advice
slmcdonald
Car: 1996 Nissan 300zx
Would it actually be better to use an all aluminum radiator or an aluminum and plastic. Also what are the advantages of single and dual core? Thanks in advance.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
plastic end tanks can break, if ti's all aluminum it's welded together and less likely to break
single row means one rw of coling pipes, 2 row means it has 2 rw of coolant passages and therfore can cool more efficiently
Z32TT
Car: 90' 300ZX TT
^ +1 the plastic over time eventually can get a small fracture which will result in overheating issues all aluminum is the way to go and better cooling efficiency same rule kinda applys with intercoolers except air is in them not fluid
