Radar Detector Install power off ignition
In 2014, the G37 Sedan became Infiniti Q50. G37 Coupe and Convertible became Infiniti Q60 under Infiniti's new naming structure - Here's the place to discuss the Q50 and Q60!
rcrisp
Car: Infiniti Q50S 2015
Q50 Owners,
I just purchased an Infiniti Q50S and I want to add a Radar detector power line? I have done this in numerous cars, but this one is going to be the most challenging to pull off. I typically run power from the fuse box off an empty ignition power fuse slot and dongle the connection with a small bus fuse then tuck the wire behind the dash up to the A pillar and up under the trim and come out just past the sun visor before the mirror. The problem on this car is the fuse box is under the hood, so before I go and run a wire thru the fire wall I wanted to ask if anyone else has found a successful way of doing this?
Thank you
Ryan
ErikMi
Easier to just tap power off the rear view mirror. Just google mirror tap, that should get you there
audtatious
There is a fuse box under the left side of the dash. I simply used the audio fuse blade to connect my Escort there.
Return to “Infiniti Q50 / Q60 Forum”
