jrd450r wrote:Not to thread jack but Im also having a coolant issue, I have air in my line between my overflow bottle and radiator, so I dont think my overflow system is working, if I add coolant to the bottle it just fills up the bottle, and if I add it to the radiator it just spills out over the top.
that part of the system is not pressurized, it doesnt matter if there is air in the line. the overflow system only works when pressure inside the actual cooling system exceeds the pressure on the cap. then the cap opens (internally) and lets coolant flow through into the overflow.
you need to fill your radiator to the max, then put a little extra in the overflow. thats it.
