rack bushings effect on alighnment
captainluigi
Car: 1996 q45t
what aspect of alighnment does rack bushing replacement effect?
i.e. caster, camber ,toe all or 2of 3 or something other.
thx
Modified by captainluigi at 10:24 AM 3/5/2008
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Depends how much shifting there was before.
captainluigi
Car: 1996 q45t
Anyone w/a beneficial response?
Brian, i ask you kindly, pleadingly, PLEASE; ignore my posts & i will return in kind. Ya just never have anything really relative.
I'm sure you're a brilliant guy, a degree in kinesiology or something as important to life. However it just seems you go outa your way to be the ............... So, what do you say? We strike an agreement here & now to just go on like neither exist.
I'm just trying to restore an old car to the best of my abilities & you are NOT HELPING!
No response would be the best.
Thank you Brian, i knew you would understand.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
No effect, IMO. Unless of course the car was aligned with the rack all crooked?
mxr662
Car: 1990 Q45 Desert Sand 81k Sold
maxnix wrote:Depends how much shifting there was before.
Actually this answer seems correct. If the rack bushing were worn enough so the rack could move around, the alignment would probably not be accurate.
What condition were the rack bushings before replacement?
If 11 pounds of force applied to the steering wheel causes +-0.08 movement of the rack then its time to replace per the FSM.
Caster and Camber would not be affected.
http://www.tirerack.com/tires/...hid=4
