rack and pinion
V8 240sx? Sure! If either the chassis OR the engine is non-Nissan (i.e. SR20 in an RX-7 or LS1 in a 240sx), we've done it.
lancer_013
Car: V8 s13 in the making
02 wrx daily cruiser
wondering how u guys did ur swap are u guys running it with out hydralic or with
Joe
lol uh what engine? what car?
lancer_013
for those who did the v8 swaps i just put a 350 in mine
Joe
in what!? sentra? 240z? 240sx? GTR? comeon! lol
dude you gotta give us info! we cant read your mind or look into your garage.
answer these:
year, make and model of car:year make and model of engine:
Davidss
Car: Z06/S2K
If you're talking about a small block chevy into a 240sx you can:
1. disable the power steering by looping the fluid line or modifying the rack2. have custom power steering lines made and use the V8 power steering pump or use a 91-95 Toyota electric power steering pump
lancer_013
so hook the chevy powersteering pump to the racxk
Joe
lancer_013 wrote:so hook the chevy powersteering pump to the racxk
i give up.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Yes you have lines made to fit the Nissan rack on one end, and the Chevy pump on the other end.
lancer_013
i dont think its goin to work because the oil pan is like 1/2 inch away from the rack i just was wondering if i could just grease it up
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Sounds like you need to moidy your pan and mounts. Mckinny makes SBC swap parts and mount kits.
lancer_013
ill try check dat site out
lancer_013
whats the web site
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
http://www.mckinneymotorsports...240sx
540sx
Car: Nissan 240SX
now that i read your post again I am guessing you mean that the oil pan sits 1/2 in behind the rack and no room for the hard lines. even with pushing my motor back about 4-5 inches I had to make a small dimple in the face of the sump. lower my crossmember then sit the engine on the mounts which are welded to frame rails, then raise the crossmember into place under the engine.
definately will need a modified pan .
Modified by 450SX! at 10:50 PM 1/11/2010
lancer_013
I'll check out that site thanks yea wen this one breaks I'll try make my own
lancer_013
So Wat is there a way I can make it work becuz I think I just broke the new one I put on
lancer_013
wheres the help
Joe
lancer_013 wrote:wheres the help
for the 4th time TELL US WHAT YOU ARE WORKING ON. AND WHAT YEAR ENGINE.
NOBODY CAN HELP YOU BECAUSE WE CANT READ YOUR MIND
JESUS CHRIST
540sx
Car: Nissan 240SX
but this is nico hybrids, of course it is a 240 with a v8.
lancer_013
ok my car is a 89 240sx with a small block chevy in it i will make an page of my build later i just put another one in with very little fulid and moved the cars couple days later the thing had broke so do they make manual one or i had an idea would it work i was think since there no nipple on the rack cuz i had to break it off if i put screws in at all the place where the lines go and fill it up with gear oil cuz its thicker would that work
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
You just dont want to run the rack dry, but I don't see the point as well. Your swappping a lot into the car, just have some lines made. (A local performace shop that custom makes -AN lines, sells fittings, etc can help you. Daft innovations is good, maybe if you send Rich the pump he can make you lines).
Any how if you want to run manual without buying a manual rack. Take the pressure and rurn line and make them the same length. Fill both sides with ATF fluid right down the lines. Leave a little room at the top of the lines for air and fluid movement (likefill the lines like 2 inchs for the top). Cap lines off and done.
lancer_013
u would have to c the pics of my swap then u would understand y i just cant do that
540sx
Car: Nissan 240SX
post pics then.
lancer_013
So I tryed putting fulided in the rack and closing all the hole It. Broke I think it was already Broking wen I itit would dat work my exhaust is right next to where the knuckle meets
lancer_013
Does anyone know if a manual rack would work from any other car
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
The sell a mnual rack for the S chassis, its not cheap I want to say 7-900 billls
lancer_013
Do u know wherE from but I'm goin to try and movemy exhaust so I can try and run power steering gotta wait toI fix my computer to c my build sorry
Return to “Hybrids”
