rack and pinion
1995Q45havoc
Car: 95 Q45
hey guys i want to replace my power steering rack and pinion in my 95Q has a leak. i was wondering if anyone can give me advice on how to make this and easy or ok operation...advice is well appreciated
Q45tech
Follow proceedure in FSM and remember you will need a reliagnment due to impossibility of getting toe correct without an alignment machine.
Why did you abuse rack by not changing PS fluid regularly? Before you replace rack try 1/4 of a small bottle [3-4-5 ounces] of Lucas Power Steering leak stop. In about 33% of cases this will swell seals enough to stop leak without damage thanks to your being in a warm climate.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Besides the Ni$$an rack, Joe sells the Meridian rebuild. I got a Maval on mine that works well so far after 3 months.
If you use M1 ATF, also use a bottle of BG Power Sterring Conditioner for the seals.
I think hadbody put a cooler on his PS system, and there is one that may be adapted from the Z32. Most needed in hot urban environment.
