rack and pinion problem????
sl240
Car: s13
I have a 93 240sx with megan coilovers the rest of the suspension is stock for now. I thought my outer tie rod ends were bad, but after inspection the play in the steering is on the inner rack side. My question is do I replace the whole tie rods or do I need to replace the rack and pinion? It does not seem to leak fluid.Also the steering wheel does not return to center after making a turn.After making a left turn the wheel is off to the left and the same when I turn right.Kinda of new guy looking for some help/info. Thanks in advanced.
nismoracingsx
Car: 1993 White 240sx Coupe
you have enough fluid in your ps resevoir with it hanging on turns like that? if the rack is not consistent in resistance while turning it left or right, the rack needs to be replaced .
sl240
Car: s13
No the steering feels smooth and free when turning. Same pressure to turn wheel from lock to lock.Fluid is full in resov. and does not leak.
nismoracingsx
well, then just replace your inner tie rod ends as for the steering not returning to the middle, perhaps an alignment issue?
sl240
Car: s13
nismoracingsx wrote:well, then just replace your inner tie rod ends as for the steering not returning to the middle, perhaps an alignment issue?
Ok thanks for the help. I was thinking about getting tein or megan tie rods any thoughts or suggestions?
LayNLow240
Car: 92 240 coupe
Go Tein. I have seen bad things with megan tie rods. I have inner and outter Teins I am about to install.
s13_maJiK
Car: s13
Caster has to do with you steering wheel return
21nemesis
Car: 1993 240SX SE
I am planning on replacing the bushings in the rack & pinion. Could I be able do this myself or should I take it to my machanic? Are there any write ups?
Thanks
