racist with cylinder 3 and 4 ?
migsk8
Car: 240sx
ok so i just bought a 92 coupe the other day with alot of shaking at low rpms. i thought it was something small. so i got the car and its only running on cylinder 1 and 2. cylinders 3 and 4 have fuel, compression and spark, im stumped and i dont know what it could be? the car runs so timing can't be too bad off.cylinder 3 and 4 do nothing when i take out the plugs. anybody have any clues?
symptoms-the motor shakes alot-smokes blue smoke-backfiring when accelerating
migsk8
Car: 240sx
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
check the wires, it might be plugged in the wrong, if they are right, then that sounds like your injectors are shot. Also your rings are bad if its burning blue
migsk8
Car: 240sx
-RJ- wrote:check the wires, it might be plugged in the wrong, if they are right, then that sounds like your injectors are shot. Also your rings are bad if its burning blue
wires are brand new, if they were plugged in the wrong way the car would not turn on. i already took out all the injectors and checked them individually and they are fine. i think the smoke is the gas being burnt in cylinder 3 and 4 because its not burning in the chamber, besides it doesn't smoke that bad at all. just regular old car smoke. the motor has 164,000. anybody have any other suggestions
p.s. the rings are fine, i already checked
Vegascorbin
Car: 1990 240sx dirt track race car
If you are showing blue smoke then you are burning oil. Fuel is black smoke. White is coolent.
Double check the plug wires are in the proper places. The car can run if they are wrong, depending on how far off they are.
If plug wires are ok, and injectors are ok, and you have compression then I would start thinking ECU.
Ajax
Car: 1991 240sx SE
2010 Mazda 5
Agreed on the wires. If it can run on 2 cylinders, it can run with two wires swapped.
-RJ-
have you tried different injectors on 3 and 4? I dont think you can tell if anything is wrong just by looking. Im thinking either you bad injectors or your valves are stuck
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
was there a cam swap on this car?..this sounds like a bent valve issue or just crappy cam timing...pop your valve cover off and rotate the #1 to TDC (top dead center) then go to the cam timing link on this forum and print that info with the pics..compare the pics with the position of your cams...if it looks off..then you have found your issue...im asuming you have the ka24de
migsk8
Car: 240sx
Ajax wrote:Agreed on the wires. If it can run on 2 cylinders, it can run with two wires swapped.
since 1 and 2 are running im gonna swap the wires for 3 and 4
migsk8
Car: 240sx
-RJ- wrote:have you tried different injectors on 3 and 4? I dont think you can tell if anything is wrong just by looking. Im thinking either you bad injectors or your valves are stuck
injectors are fine, i cranked the car over and watched them shoot out the gas
-RJ-
then im gonna go with bent valves, unless cams were swapped like liquid cool said
liquid_cool
bump for updates
carmo
Car: 92 Accord, 90 Civic, 89 240sx
I have seen on certain Nissan motors where the signal plate in the distributor will get soaked in oil because the distributor shaft seal begins leaking. When this happens, the car will run like crap if it runs at all. I still might be worth taking the valve cover off and manually turning the engine over to see if any valves are hanging up. But if you had bent valves, you would think the compression test would show that.....
migsk8
Car: 240sx
liquid_cool wrote:bump for updates
no bent valves, haven't changed the dizzy yet cuz its almost brand new, and theres no oil in it. im stumped :[
Vegascorbin
I think we are missing something here.Going back to the original posting:
migsk8 wrote:-smokes blue smoke
Where is the blue smoke coming from? I think you will find it is all related.
-RJ-
Blue smoke usually means bad rings. are you sure the previous owner didnt do anythign to the motor? was it like this when you bought it?
if you were only closer to va beach, id try to go and help you in person
migsk8
Car: 240sx
im in newport news, 30 mins away haha :]
-RJ-
thats too far lol
Orlandos13
Car: 1989 Nissan 240sx KA24(e) s13
You should check your distribuitor............
migsk8
Car: 240sx
its new
ilovesideways
Car: 240SX S-13 KA24E
how exactly did you "check" your rings?
migsk8
Car: 240sx
i compression tested it, its not smoking bad so the oil rings are fine
ilovesideways
what were your compression test numbers on each cylinder?
Vegascorbin
If enough oil is getting into the cylinders to create visable smoke then things are not fine.
lilke ilovesideways asked, What are the compression test numbers?
ilovesideways
Vegascorbin wrote:If enough oil is getting into the cylinders to create visable smoke then things are not fine.
Maybe the numbers are on the low side but not exactly bottomed out? In which case would explain why there is only a little smoke.
migsk8
Car: 240sx
its 170-180 all the way across, it has 164,000 miles, the cylinders are good
PapaSmurf2k3
Site Admin
Bent valves would kill the compression. How do the plugs look? Are they covered in crap? Gapped correctly? Any vac. leaks anywhere? Will it fire on all 4 cylinders if you spray starting fluid in there or something to that effect?
migsk8
Car: 240sx
plugs are new
PapaSmurf2k3
Site Admin
doesn't mean they can't be fouled, or covered in fuel, or bone dry. I didn't ask how new they were, I asked what they looked like. How about the other suggestions, any luck?
migsk8
Car: 240sx
if i remember right from last time i was over there, they had fuel on them, very little but it was still on there. no luck on the other suggestions. next time i go over im gonna switch the dizzy wires around.
