i can't speak for myself since joe did the install for me, but it's pretty straight forward. get your car on a pair of ramps (you don't want the car jacked up for this), 2 bolts on one brace, 1 bolt in by the tire and done. here's a few pics:
the two bolts on the right side are the one's used to attach the bracket, just slip the bracket between the oem brace and the car.
i believe that this was an empty hole under the car that was used, just attach this end of the traction rod with a bolt that's supplied with the kit
