adidas2go »
https://forums.nicoclub.com/adidas2go-u78832.html
Mon Dec 08, 2008 4:19 pm
Alright guys, here it is! Sorry the pictures are a little dark, but I installed this after I got home from work, near sunset.
Logistics:
The kit comes with the tower bar, 2 bracket plates, and 2 long 13mm bolts, 2 16mm bolts, and 2 16mm nuts.
I will be writing instructions for this tonight, but I thought I would show the pics, and a few details now.
When installing this, use 2 stock bolts from the brace, and 1 long bolt (supplied with the kit). You have to install all 6 bracket bolts at the same time. However, only initially install them about 4 threads down each, started with the back bolts and moving forward. You will see why when you install it. It molds the bracket to the strange upper strut body, and makes a solid hold. After your have all the bolts started on both sides, put the tower on. Secure the tower to the brackets with the 16mm bolts supplied.
Now, this is where things may get tricky. If you screwed the bracing bolts in too tightly, the tower wont line up correctly. You will need to back the bracket bolts off enough for all the holes and bolts to line up enough. Tighten them all slightly, a few threads at a time, alternating between them to get the tightest fit, without stripping the threads of the bolts. Don't let this intimidate you, its fairly simple. Think of it as putting you cars wheel on, and the way you have to thread all the bolts on in a pattern to prevent stripping. Same thing here.
After you have all the bolts in a position where they line up and are tight, tighten the bolts connecting the tower to the brackets. These should have been in the whole time while you were going through your alternating ordeal, but you should have tightened them till now. Make sure you give all of the bolts around 65 ft lbs of tq (about 3/4's of a turn past tight). After than, YOUR DONE!
Driving thoughts. The front end definitely has a tighter feel. Almost as if the sub frame has changed. Its hard to describe, but a noticeably better feel. Sticks to the road, that for sure.
Without further ado, here is the finished product! Again, sorry about the blurry pics.
