im not sure that was a good ideaben2mx wrote:What I totally didnt like was that after I installed it, the links wouldnt connect to the bar since the holes where not big enough and I had to take it down again and drill them a little bit bigger. I am very surprised Racingline didnt double checked that.
The bolts are 16mm.ben2mx wrote:The only thing is that I wish someone made a more detailed description on how to install it since I made a couple of mistakes. Specially the instructions from the manufacturer should tell you exactly what tools to use since I dont have any tools and I had to go twice to autozone to buy the correct ones (many people said 17 mm and 19 mm, but that didnt work for me, only 5/8, the extension, ratchet, jack, jackstands).
Remember to post the pix! I'm a future buyer, so would like to research on installation before I buyben2mx wrote:I installed it yersterday. There is many things I want to address. I will start with the good stuff. It performs very well. I love the way the car now handles. The stock RSB is like comparing a straw with a pen. The only thing is that I wish someone made a more detailed description on how to install it since I made a couple of mistakes. Specially the instructions from the manufacturer should tell you exactly what tools to use since I dont have any tools and I had to go twice to autozone to buy the correct ones (many people said 17 mm and 19 mm, but that didnt work for me, only 5/8, the extension, ratchet, jack, jackstands).
I did took some pictures that I will post later.
Let me see if I can post pics (Ive never done it). But if you go to stillens webiste, on the sway bar for altima coupe, they have a PDF file with good instructions. If you read those and others that have been posted, they will help you. Its really not hard, but then again, you want to be able to have everything you need to buy it, install it, and enjoy it.darkmessenger wrote:
Where did you get the grease pack because i did not get one.Thats the only thing that is holding me back.duffman8189 wrote:Damn, am I the only one still having trouble installing this part?
