I'm having an issue with my RL Strut Tower Bar as well, just wondering if any of you ran into this and your thoughts on what I should do.
After much struggling I got both brackets bolted in place; one went in fairly easily but I could not get all three bolts on the other one to line up at the same time for the life of me. Eventually I was able to get it with an extra pair of hands, but as you can see in the pic I posted the bar itself doesn't line up with both brackets.
I've thought of two options to get around this unless someone here has a solution, and they are: 1. Drill a new hole through the bracket where the bar sits, or 2. I can bend the bar enough to slide the bolt through, but it seems like way too much flex considering it hits the rubber hood seal.
Any advice guys?
