Racingline Grounding Kit /AEM?
All things Altima Coupe.
rcboy514
Car: 2013 VW Golf TDI 4dr 6-speed
2008 A/C 3.5 CVT (sold)
2004 BMW 545i V8 >:-)
1991 BMW 535i I-6
Just wondering if anyone has this set up, I've heard some of the wires aren't long enough if you have the AEM intake because the "heat shield" gets in the way.
Any ideas?
Jman0711
Car: 2008 Altima Coupe 3.5SE
Also a bit curious about this, i just installed my AEM. I'm just waiting for warmer weather to put my grounding kit. I have the Sentient one though.
Coupe12
Car: Nissan altima coupe. 2008, 2.5S
Will sentients fit with injen?
rcboy514
1991 BMW 535i I-6
I'm pretty sure all the grounding kits will fit with an intake that doesn't have a huge heat shield. I do remember reading a while back that sentient said to let him know which intake you had so he could adjust the length of the wires accordingly.
Racingline
The racingline kit ( both 2.5 and 3.5) circle around the back under the intake, I can't really see how it will interfere with any intake. The SBD kit (iirc) does however criss cross over the intake path
RicerX
Car: '20 Titan Pro4X
RL - I think what he's concerned with is the massive heat shield that surrounds the intake piping on the AEM application. There isn't much room for a grounding kit wire to go, and I highly doubt it's long enough to go underneath it. It might work, it might not work.
rcboy514
1991 BMW 535i I-6
Thanks for the info! It seems like there are enough positive effects (drastic or not) to justify spending the money. Plus it dresses up the engine bay nicely.
rcboy514
1991 BMW 535i I-6
XenonSE-R wrote:RL - I think what he's concerned with is the massive heat shield that surrounds the intake piping on the AEM application. There isn't much room for a grounding kit wire to go, and I highly doubt it's long enough to go underneath it. It might work, it might not work.
yeah, that is what I was referring to. Having the wire be long enough to effectively reach.
Racingline
I know what was meant, my point was that none of the RL wire travel over or under the intake path. 1 side follows the batty/fender, another the engine block itself, and the other the timing chain side. Non of the RL wires actually cross the intake path ever. Now the intake would no doubt hav e to be removed to facilitate the grounding kits installation, but once the kit is installed the AEM intake would fit back into place
rcboy514
1991 BMW 535i I-6
Gotcha! :bigthumb:
RicerX
Racingline wrote:I know what was meant, my point was that none of the RL wire travel over or under the intake path. 1 side follows the batty/fender, another the engine block itself, and the other the timing chain side. Non of the RL wires actually cross the intake path ever. Now the intake would no doubt hav e to be removed to facilitate the grounding kits installation, but once the kit is installed the AEM intake would fit back into place
Sweet! Looks like your grounding kit will be ordered by me soon then. That part is on my list of things to get for the summer. Thanks much for the input!
