I have removed from my 1996 project Q the sound system, air conditioning, air bags, back seat, my reveled heated seats and the sound deafening tar (from the back seat area). This has reduced the total weight by a few hundred pounds. I’ve added racing seats and a cage. In all I’m about 3,800 pounds.
There is much weight to be lost in all the wiring harnesses. I am amazed at the amount of wire associated with the air bags. Removing wiring appears to be a daunting task that is riddles with danger. Any suggestions on how to proceed?:help
I should also lose weight by replacing the glass windows? Has anyone done this in the Q? Is there a source? If not I’ll go custom. :help
Most of the front dash remains and looks decidedly out of place.:thinker
AZ has suggested that I put the battery in the trunk where the CD player was located. I am considering this as part of a package where I also install a keyless ignition and system gauges. Any suggestions on this effort?:help
I have considered installing a computer to track and record systems information. Thoughts? Recommendation?:help
What should I consider in installing a fire suppression system?:help
