dgoodno wrote::help :help :help :help :help :help :help :help :help Ok, so we have good advice on the camshaft and rear differential. One of the major problems on the track is overheating.
I am very aggressive on track. Either the gas or brake pedal is pushed to the floor. Because of the brake problem mentioned in the last two threads, the engine is often used for braking on the hottest turns [coming off the long straight]. Besides, on most tracks I'm only out of second on the long straights.
I do have the modified chip and therefore run at higher rpm, although even before then they (all my Qs) ran hot on the track.
I have removed the air conditioning and added an air scoop lower front. I had toyed with installing an oversized flex fan along with a number of other options.
What has been done -- and has anything worked? :thinker
If you haven't already done so, run no more than 20-25% anti-freeze and add some Redline Water Wetter, which improves heat transfer. If that doesn't work you'll probably need to get a new oversized radiator, which might need to be custom built, although you might be able to find an off the shelf unit that fits. One thing to definitely not try is to replace the stock engine driven fan with electric fans. They don't move as much air as a good sized engine driven fan no matter how many million CFM they claim to move.
Another idea that is probably needed anyway (do you have an oil temperature gauge?) is to add a good sized oil cooler to provide another way for the engine to dissapate heat.
Eric
