j-z »
https://forums.nicoclub.com/j-z-u11653.html
Mon Apr 27, 2009 6:05 pm
i tried to help by trying to tell you that youre over engineering something on a street 240. were not trying to be germans on this forum. it would be so simple and easy to cut the pedal itself off the lever, position where you want it, and weld it back. instead you want to move the entire assemblies around. you know the BMC has hardlines going to right? use common sense, and weigh in the factors. seems like a no brainer to me. however, i never had any problems rev-matching/heel-toe braking in any of my 240s. for some cars, i dont know about the 240, but ive seen where they make pedal extensions for the brake, and gas pedal. you can look into that and see if anyone makes one for the s chassis. if not, get some and adapt them.
