I have a new ACT heavy duty racing clutch and ACT light weight fly wheel combination.
this is word for word what the instuctions say that came with the cutch.
so that seems like it is giving to options on either end of the spectrum. So why cant i just go out and drive the car how i would normally drive it. because it seems like if it does slip it will be lapping the surfaces together like it should be and if it doesnt slip then it will be fine......ACT INSTALL INSTRUCTIONS wrote:Recommended break in for ACT Street Discs is 200-300 miles of mild street driving. Break in for the ACT Race Disk can be accelerated by performing several hard slips in high gear prior to racing. Allow the clutch to cool for about 10 minutes between these slips to prevent over heating. The purpose is to lap the surfaces together under controlled load so the full surface makes contact.
and what does it mean hard slips in High Gear? how would you go about doing that.
i dont want to glaze my clutch and fly wheel and that is what i am worried about doing. so i wont be running high boost just the boost level that the acuator is set for. i think it is like 7 psi.
also it seems like if i let the clutch out in low rpms then get on it then it will be fine it would just be the transition when i make the shift if i have it really reved up that it could glaze it. so i should be able to let it out get on it pretty hard when it is engaged. then let off the gas let the rpms drop back down to about 3000 before making my shift into the next gear..
main thing is i havent be able to drive my car for about 8 months. and i want to feel the boost lol.
